Tommi S Rapid Tommi S Rapid
komentáře | popis | fotky | Tommi S | 27.04.08 14:49 | 308x v oblíbených
Skoda Rapid Coupe 130 RS
Original 1.3 l motor
Dellorto DHLA 40 with K&N filther
New exhaust manifold and silencer
Lowering springs (made from originals)
16" Alessio Monza wheels
Ventus 205/45/16 tires
Ellri front- and backbumpers
Ellri sideskirt-set
Single windscreen wiper system
Interiour
2 Sportseats
4-point safety-harness
Skoda Felicia Dashboard
Self-made doorpanels
Center konsole from Volvo 440
Back seats removed, and builded full of audio stuff.
+ Lots of allkind of little stuff
ICE
Pioneer Mp3-player
2 x Focal Access 6,5 two-way speaker sets
12" MDS X-MAX subfoower
Xetec 6-channel amplifier.
< Update > - 27.09.2003 I uploaded some new pictures =)
< Update > - 05.07.2003 We went to Finnish racetrack happening in Ahvenisto's racetrack here in Finland. There was this Radalle.com happening where people can test they own car in the track. We tested Rapid =) Rapid was really good to drive in track, first it was very slippery because the raining but when track dryis down it has very good grip. - 2 new pics =)
< Update > - 22.06.2004 Here is some pictures from Finnish Skoda meeting at Kurikka www.kapsi.fi/~needforstre et/.../5.%20Skoda%20kerhon %20kokoontuminen%20Kurikka %202004
< Update > - 12.09.2007 Here you can find bigger pictures of my EVO2 Rapid. s5.photobucket.com/albums /.../Rapid_big All pictures shoud be about 1048x768 resolution.
Sorry I only speak English and Finnish so if you have something to ask try ask in English =)
Find out more @ www.skodapower.tk/ or www.needforstreet.tk/
Tommi S Rapid - komentáře:
19:41:36
15.11.2006
dial K for Karlos
-> Tommi S: I think, that it may be problem. I am owner of 135 RiC, but here in Czech Republic, there is no parts for RiC or GLi .. But much parts for this injection system are from Renault, so You must find the similar rather same lambda sond for any type of Renault, than You can try to search for it. It is probably much more easier. Have a good luck in searching.
19:25:01
15.11.2006
Tommi S
I NEED HELP !
I cant find right lambda sensor for Skoda 135 GLI here from Finland. If you know where to find correct one, please help.
19:23:55
15.11.2006
Tommi S
-> Martin_86: I used some plywood, seamfoam, fiberglass, and putty. Then some imitation leather and glue.
21:00:56
27.08.2006
Martin_86
Your car is beautiful,it h´ve a style.Can you tell me, how did you make these door panels???
14:34:15
09.03.2006
guco1
first whells is good.
15:44:12
26.02.2006
Pilot 105
-> Tommi S: You have to order 6 pieces. Prices in pricelist is for 1 piece.
www.prondo.cz/cenik/cenik en.php?Podle=Cisl...
20:50:21
25.02.2006
Tommi S
-> Pilot 105: OK, So i have to order 6 x 114010180 that part Or are they all 6 in that one package ?
17:22:57
24.02.2006
Pilot 105
-> Tommi S: The regrinded ones are not modified. The difference is only in inner diameter as I wrote. "D" is the diameter of main bearing on a crankshaft. A new crankshaft has D=60 mm, each regrind takes in most cases 0.25 mm. If you have a new, non-regrinded crankshaft, buy 114010180. The best way to determine which kit you need is to measure (accurate enough) the diameter of main bearing on the crankshaft. It should be one of 60.00, 59.75 or 59.50.
20:23:16
22.02.2006
Tommi S
-> Pilot 105: Are those regrinded somekind of modified ? I would need only standard size main bearing kit.
13:13:16
21.02.2006
Pilot 105
-> Tommi S:
Hi, you can order main bearings for Skoda 130 engine here: www.prondo.cz/cenik.php
Catalogue numbers are:
114010180 new crankshaft bearing shell D.60
114010181 crankshaft bearing shell after first regrind D.59.75
114010182 crankshaft bearing shell after second regrind D.59.50
19:14:59
20.02.2006
Tommi S
Hi, I would really need help now. They dont sell 130 Main Bearings anymore here in Finland. Is there any place there in czech were could I order those. Here is the link to picture what i mean. i5.photobucket.com/albums /.../sample.jpg
22:57:26
09.02.2006
formelak
-> zufo: 3 Finland?
22:55:15
09.02.2006
M.a.r.i.o
Je to palubka Felicie 4
22:26:51
04.10.2005
itchy
-> zufo: nepripomina ti to Feliciu? A chlapik je spoza hranic
22:25:08
04.10.2005
zufo
tak to je borec odkud je???? a tu palubku tam ma zceho????
15:02:19
12.09.2005
mbcko
Very nice
4
08:42:03
08.06.2005
Rooney - zrušená registrace
Sice nejsem příznivec plastů , ale vidím, že když to někdo umí tak je to fakt super!!!!!!
Hooodně pěkný Rapídek!!! 10b Jukni na mojeho.2
22:27:24
24.04.2005
Mishak
Nice one ... 10 points for you mate4
22:01:05
22.04.2005
Kroulíček
Tady neni co češit super!10.b!jukni se nam muj stroj!4
11:49:44
12.04.2005
Bukyn
Super 10b 5
