Favorit 1500 Favorit 1500
komentáře | popis | fotky | Favorit 1500 - zrušená registrace | 03.07.09 20:04 | 55x v oblíbených
Engine:
Favorit 781.136
1510cm3, 78 x 78.4mm, T-pistons
crankshaft: fabia
camshaft: 320/320
compression ratio: 13.0:1
cylinder-head: type 31/37
exhaust system: 4-1 ; full 60mm
2x weber dcoe45 carburettors, 38mm venturies
forman gearbox (in 2009 with a special shorter 4th gear until 165km/h trap speed)
fuel: OMV 100 octan +++
Body:
light weight :) 645kg + driver
2009.02.24.
measuring with a MUSTANG MD-250 2WD dyno:
164Nm(4750)
140-145Hp(6800) @ flywheels
First places in 2008: Slusovice;Trencin;Piestan y in category 1600
best time in 2008: 13.95s@153.8km/h (402m) @Tokol Airport_31.05.2008
best time in 2009: 13.54s@163.6km/h (402m) @Tokol Airport_21.06.2009
Skoda S100 1.4 vs. Corsa V6
Normanrls S100 1.4 (HUN) vs Corsa 2.5 V6 (HUN)
Favorit 1500 - komentáře:
07:31:37
06.09.2009
BoiBlu
favorit 1500..ive seen your car in a number of videos for YEARS and i was amazed as to how well u have modified your car to do 13+ second in 402m. Great work man!!6
15:39:35
26.05.2009
TheronBB_130LR
-> Favorit 1500: congratuôation to the wedding and great times in the sprints... your favorit is so cool .. like my dreams.. but your dreams is true :D and real... go go go 0-100 5 seconds???9 9 9 i dont belive it 3 3 i must see it
21:06:37
25.05.2009
i have to skip most of the foreign races (CZ & SK) and i only concentrate to the domestic ones for prize money. It seems that i skip slusovice too :-( Because of Wedding:-)
My enemies are: hungarian Skoda S100 1.4 (135HP) with 13.88@158 & polish Suzuki I Gti (230HP@11000rpm) with 13.22@165
bye: Myki
20:50:34
25.05.2009
slucovice 13,539? they measured only 350m...
i have a new and real record: 13.59@163 & 13.54@161
timeslip.hu/verseny.php?i d=132&...
0-100km/h : 5.3s
23:58:29
23.04.2009
TheronBB_130LR
hello man this car is so strong like i see... and good sound of engine3
00:09:29
23.04.2009
Mlhoš - zrušená registrace
hello in slucovice you hav 13,539 auto-show.tuning-sport.cz /vysledky/vysledkyV_do_160 0.pdf (no 13,95)
21:55:37
08.04.2009
yesterday we measured the weight of the car: the race version is only 630kg + driver (75kg)
We realized in the carburettor that the jetting was terrible! 155/240. it means the air/fuel mixture was quite weak. 1.cyl: below normal; 2.cyl: weak; 3.cyl: very weak; 4.cyl: weak. at the 3rd cylinder somehow the exhaust valve couldnt close well. additionally realized other problems as well. at the moment we working on it... good news the modified 4th gear is done:)
my first CZ debut: may.9 at Mimonske valky! bye
19:35:28
11.03.2009
we use to say its a 31/37 cylinder-head :)
"Did you build it by yourself or someone else did?" - partly myself.
The camshaft is an original CZ one. The crankshaft is a normal fabia from the 8v engine without lighting.
20:41:06
09.03.2009
-> Favorit 1500: Pretty nice engine. I would like to have same power as you do.
Did you build it by yourself or someone else did? There is only normal Fabia cam?
I guess that 31/37 are valves, not cylinders4
20:06:43
09.03.2009
andre
-> Favorit 1500: well, thats pretty good anyways, thumbs up for you ride, it dosnt matter if 130 or 120 hp, you achieve very nice places4
19:59:04
08.03.2009
today we measured the favorit's acceleration with a special instrument. unfortunately the 153hp is not true! :-( it's only 136-140hp... (117-120 Wheel horse power instead of 132)
20:55:31
05.03.2009
at Slusovice i did the race with 2 x Weber 40Dcom, bad spark plugs and plus 20kg. the car was about 132hp not more...
at the acceleration diagram you can see the green line which is horsepower on the wheels. To the flywheels u have to times it with a factor 1.17 because of losses.
20:47:07
05.03.2009
thanx everybody:) well, Mimon's War isthe furthest sprint400 from Budapest: 2 x 585km with this car...
hopefully at this weeked we do another acceleration test so we will know whether the 153hp is true or not 4
16:36:19
05.03.2009
favo110lrs
-> Tomicraw: jsem zvědavej co na to řekne Jarda Pešan:)
15:21:04
05.03.2009
paradni raketa na sprinty.....mozna se potkame
10:23:48
05.03.2009
Tomicraw - zrušená registrace
09:37:07
05.03.2009
Mr_Kubas
-> favo110lrs: Tady to má napsaný 6 forman gearbox
22:19:01
04.03.2009
favo110lrs
docela rychlik:)co tam más za gearbox-?
21:52:31
04.03.2009
Evž@
-> Tomicraw: jj...taky jsem čuměl
21:20:14
04.03.2009
David V6
super
