-> Pitrys:
For example:
-90095Canada~1988.10.
-90365Hungary~1988.12
-90611Hungary~1989.01.
-90674Hungary~1989.02.
-90703Hungary~1989.03.
-90717Hungary~1989.04.
-90784Hungary~1989.04.
-91095Finland~1989.06.
Skoda135 GLi 04/1988-08/1989
Compression: 8,8:1
Power at 5000rpm is 41KW
Torque at 3500rpm is 92Nm
Transmission: 4,22:1
Max.speed:140km/h(Skoda Rapid135i:148km/h)
Inlet valves: 0,25mm
Exhaust valves:0,20mm
Fuel pressure:0,75Bar
Ignition spark advance:14 +/- 5 crankshaft degress
Alternator pulley:Skoda 135i Bendix
Distributor:443 213 204 720 Skoda135i Bendix and Favorit135Le,Lse
Plug leads:Ripaults SU267P
Flywheel:Skoda135i Bendix
Inlet manifold:Skoda135i Bendix
Exhaust manifold:Skoda135i Bendix and Skoda135,136,Rapid135,136
Air cleaner body:Skoda135i Bendix
Mechanical fuel pump:Jikov OD3457 Favorit1987-1992
Emission very good:CO 0,1-0,2%, HC 50-60, Lambda:1,00-1,01
(New Oxygen Lambda Sensor+Catalytic converter+Modifications E.C.U.)78000km
Injector:Renault 5,9,11,19,21 1.4i,1.7i(8983500063)
Throttle Position Sensor(TPS):Jeep Wrangler 2.4i,Cherokee 2.4i(1987-1990),Renault 5,9,11,19,21 1.4i,1.7i Automatic transmission(8933000169,3 3000169)
Idle speed actuator:Jeep Wrangler 2.4i,Cherokee 2.4i(1987-1990),Renault 5,9,11,19,21 1.4i,1.7i(8983502375,8350 2375)
K3727010(90365)White 12/1988
K3745835(90611)Apollo Red 02/1989
K3748523(90674)Brown 03/1989
The first model chosen to comply with the US-83 Federal is Skoda 135i.To accelerate the development,cooperation has been establised with the American company Bendix Electronics which manufactures an electronically controlled,single-point fuel injection system for Renault R9(Alliance) and Jeep 2.4 l cars destined for the US market.Components of the system have been employed on the Skoda 135i car,with just a few minor modifications,the most important one concerned with the electronic control unit optimizing the car engine operation.A single-point,electronical ly controlled fuel injection/ignition system manufactured by Bendix is employed to blend the fuel mixture in an optimized manner to ignite it ,which features a feedback from a lambda probe fitted into the exhaust pipe.The additional combustion of exhaust fumes takes place in a catalytic converter situated upstream of the exhaust silencer.The system guarantees that the provisions of the most stringent US-83 Federal regulation are met for at least 80.000 kilometres.
Imported parts:
2. Injector body 004-301374
7.Coolant temperature sensor 004-435006(Renault 7700737571)
8.Air temperature sensor 004-435007(Renault 7700737572)
15.Fuel filter 004-312109(Fram G3641 8933000076,33000076 Renault,Jeep)
16.Fuel pump 004-319153(Walbro NO.5611)
17.Activated carbon tank 007-622031(AMC 8933000056,33000056 Renault,Jeep)
19.Hose 005-311291
20.Hose 005-311286
21.Clip 007-606195 2pcs
22.Clip 007-606194 2pcs
34.Catalyst c/w accessories 003-245009(Walker UOP 4C PMR-102)
35.Packing ring 005-416095 (Walker AMC 8933000112, 51x66x14)
36.Stud 005-221556(Walker AMC 8934202175)2pcs
37.Nut M12 005-285334(Walker AMC 11502723)2pcs
38.Conical spring 005-056159(Walker AMC 8933000534)2pcs
46.Oxygen probe 004-165006(Autolite 3235910) 3 wire special titanium, only Skoda135i !!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!
47.Revolution scanning unit 004-165005(S100540015)
48.Electromagnetic valve 004-387121(Rostra T820100)
50.Sparking plug 004-081152(Bosch F7DC)4pcs
57.Indented belt 943-097509(Continental Foza V 10/9,5x1000La)
58.Battery 004-016139(Pakassaku Fi. Super Power 827)
60.Underpressure sensor 004-165007(ACDELCO 16018622) "876"
61.Control unit 004-046001(S100817101A) only Skoda135i !!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!! !
62.Ignition unit 004-050004(S100620-005A)
63.Series resistor 004-073121(AMC 8933000764)
66.Wiring harness 007-902444(Labinal Fr.)
68.Hose 005-311295
69.Hose 005-312487
70.Hose 005-320200
72.Fuel tank 007-650508(Kautex)
74.Hose 005-320202
81.Hose 005-311288(CPIO)
82.Hose 005-311290(CPIO)
83.Hose 005-311287(CPIO)
84.Hose 005-311289(CPIO)
91.Relay 004-025114(ELMOT 541 Poland 30A)2pcs
Compression: 8,8:1
Imported parts:
19.Hose 005-311291
20.Hose 005-311286
68.Hose 005-311295
69.Hose 005-312487
70.Hose 005-320200
74.Hose 005-320202
Robi135GLi-HU - komentáře:
-> Pitrys:
1989 "K" model 135GLi,136GL(Kvasiny)
90365-1989 365.pcs
90611-1989 611.pcs
90674-1989 674.pcs
~max 1400pcs
90365-1989 365.pcs
90611-1989 611.pcs
90674-1989 674.pcs
~max 1400pcs
Robi---what is it number in the picture 15,16?!
Robi---yes 700kč,it is good
![133](http://img.skoda-virt.cz/x-smajlici/133.gif)
-> Pitrys:
Mixture sensor 700Kc???
![179](http://img.skoda-virt.cz/x-smajlici/179.gif)
Robi---have you a new your sensor?in czech republic about 700kč
not buy?:-(((
![10](http://img.skoda-virt.cz/x-smajlici/10.gif)
![11](http://img.skoda-virt.cz/x-smajlici/11.gif)
![12](http://img.skoda-virt.cz/x-smajlici/12.gif)
Non-existent spare parts(Walker Catalyst,Autolite Oxygen sensor)
Autolite(Made in U.S.A.)
-> Pitrys:
Oxygen sensor Autolite3235910 Special Titan(Skoda135i car) there is not
-> bnjaro:
Érd(near Budapest) Madarsko(Hungary)
Robi---it is a pity,go buy lambda originál and catalyst originál?
![148](http://img.skoda-virt.cz/x-smajlici/148.gif)
-> Robi135GLi-HU: a slovensky??
-> Pitrys:
![51](http://img.skoda-virt.cz/x-smajlici/51.gif)
Robi---ty umíš česky:-)?
-> Pitrys:
Mixture and Coolant temperature sensor Measurement:
20 degress:~1600 ohm
90 degress:~130 ohm
NTC!!!
Original Renix(Siemens) sensors! Made in France
90 degress:~130 ohm
NTC!!!
![28](http://img.skoda-virt.cz/x-smajlici/28.gif)
Robi,very thanks in informations
![111](http://img.skoda-virt.cz/x-smajlici/111.gif)
![156](http://img.skoda-virt.cz/x-smajlici/156.gif)
this sensor have name Renix or Bosch or other?
![227](http://img.skoda-virt.cz/x-smajlici/227.gif)
![225](http://img.skoda-virt.cz/x-smajlici/225.gif)
how this a sensor have value?
![203](http://img.skoda-virt.cz/x-smajlici/203.gif)
-> Pitrys:
Clio,Rapid,19,21,Megane,L aguna,Safrane,Traffic,Espa ce
