Draxo Draxo
komentáře | popis | fotky | MOLSO | 10.09.20 08:08 | 474x v oblíbených
popis ještě nebyl přidán :-(
Draxo - komentáře:
09:44:47
25.08.2016
Kalash
Hello 1
Thank you for answering my questions.
Could you please tell me what is the size of the diffusers and the jets that you are using now ?
I have started a new project and i like how your car runs.
On my older car i have 21.5 and 26 diffusers size and i'm running with 200 - 120 and 160 - 145.
the only difference is that i'm using a felicia engine with the standard cam 254-254 and i think the lift is 6.1 .
Maybe i'm wrong about the lift of the standard 136 b cam but in Romania is hard to find this kind of information.
Thank You
22:30:22
24.08.2016
-> MOLSO: Stihl. Sa pýtaš ako sprostý3
18:18:40
24.08.2016
-> minno: dolmar alebo stihl ? 40
-> Kalash: Hi 1
Thank you 4 1 I try to answer your questions .....
1. - I don´t know exactly specification of my camshaft, it is something about 290 - 300° .
2. - Yes, I´m using Jikov SEDR 2951 (for Skoda 130), but it has bigger diffusers. Jets are modified too, It was finally tuned by wideband oxygen sensor in whole spectrum of rpm.
3. - 890 kg was weight with spare wheel and accessories, with cca 10 -15 liters of fuel.
4. - Original speedometer is very inexact, so I cant answer on this question.... But I can try to measure it with someone with GPS 40
14:39:52
24.08.2016
Kalash
Hello ,
Grettings from Romania 1 .
You have a nice car , i have watch also the movies that you have uploaded on the page and your car runs great .
I have some question for you 1
1. What specification has your camshaft
2.From the picture i see that you are running with the Jikov Carb. Have you modify the ventury or is a stock carb.
3.I see a picture with the weight of the car of 890 KG. This weight is with the Spare wheel and accessories or without them.
4.Estimated power on your engine and 0 - 100 time .
Thank You
08:16:11
23.08.2016
-> MOLSO: Riadna píla :)
23:56:25
22.08.2016
darabos
157
22:52:06
22.08.2016
Po vyčerpanom dni dovolenky a návšteve urbiho sa nám podarilo vydolovať z motora maximum nastavením správnej zmesi a predstihu v celom rozsahu otáčok - naozaj som bol prekvapený, aké rezervy ten motor v sebe skrýval a kde všade ešte dokázal urbi nájsť "stratené kone".
Po odstránení jedného drobného nedostatku v Náseldoviciach to jazdí nádherne plynule a má krásny záťah. Aj týmto by som sa Urbimu chcel ešte raz poďakovať za snahu ochotu precíznosť a deň stratený jazdením a prepisovaním máp 6 ĎAKUJEM !
A tu je nejaké to videjko zo sobotnej akcie 5
Slalom show 20.6.2016 - Dunajská streda
upraveno 3x, naposled 22.08.2016 22:53:49
22:38:56
07.08.2016
MajoLR
-> ZdrubT 07.08.16 22:35:20: Hnusné to je fuj...3 3 3 Ale ide mu to trošku...40 3 157
22:35:20
07.08.2016
ZdrubT
-> MOLSO: Jede to hezky a vypadá hezky.
22:20:21
06.08.2016
-> Eidy: ale hybaj 3 zase až tak horké to nebude 4 1
-> MajoLR: Ď 4
22:19:10
06.08.2016
MajoLR
22:05:46
06.08.2016
-> MOLSO: Na tebe si budeme muset dávat pozor, až se zase potkáme na srazu/slalomu. 4
21:24:37
06.08.2016
Slovakia ring autoslalom race II - 6.8.2016 - J. Galbavý, 3. ostrá
1
14:33:37
08.07.2016
-> Ultim: mozes hadat 1
14:20:49
08.07.2016
Ultim
-> minno: Ta 5° pak bude jako normální 5° ze 3,9.
Jako jo, asi bude potřeba trochu vytočit 4°, aby se ta 5° chytla, ale díky 4,22 převodu to bude mít dobré zrychlení. Prostě jen udržovací rychlost na delší trasy.
14:02:08
08.07.2016
-> Ultim 08.07.16 13:39:26: to zas bude ale tá 5 potom v náväznosti na 4 moc dlhá, nie?
13:49:26
08.07.2016
Ultim
-> MOLSO: Jedes 13 - 14.8. do Nasedlovic, nebo na CS sraz na Javorinu?
13:41:14
08.07.2016
-> Ultim: sprinty nejazdim, slalom je omnoho zabavnejsi 1
13:39:26
08.07.2016
Ultim
-> MOLSO: Hmm.. ale zase to má menší odpich při sprintu ne?
Já chci kupovat delší 5° se 4,22 tak aby to bylo zase jako 5° se 3,9 4
