Engine-781.135M -AMG with ECU Felicia 50kw only for spark, and Skoda Favorit intake manifold with carburetor adapter from SP-EL.cz and Skoda 135 carburetor, runs very,very,very well :)
Increased compression ratio, two springs on the valve, cylinder head porting
Felicia starter with reducer
Gearbox 5 speed- 3.90 with back system from Rapid 130.
Brakes: Front all system from Rapid 130 with 4 pistons, Back Caliper VW with pads, disc VW polo
All of the wheel hubs modified to 4X100 PCD
Springs: back Koni spring yellow from 130LR - front original 130L(soft springs)
Shocks: back Bilstein gas Ford Escort Cosworth(Minor modification) - front Mitsubishi Pajero 3.0 V6 with hardness adjustment
Exhaust: Citroen C1 modified (So it sounds like stock)
Wheels: KN Diamond 14x6J PCD 4x100 Made in England very light wheels (Same manufacturer as original Skoda alloy wheels)
Tires: front and back - 165/70/14
I don't understand Czech. Please write in English.
If it is possible send me complete number from that ECUs I can ask one of my frine who works in Česana (Škoda Auto - electric department) maybe he can help in this case.
Or take a picture of stickers from both of them, it will be sufficient.
Do you know the difference between ECU 40kw and ECU 50kw from Skoda Felicia? Is a difference between them? Or difference is the engine only. Thanks in advance!
-> nyk23 14.11.15 22:23:19: I think, this headlight glass isn't manufactured. But someone grinded this from original glass. Maybe you will find some manufacturer or someone, who know make this from original glass .
