Skoda 120 1987
previously it was 1.3 MPi, now subaru impreza engine (EJ20 N/A, standard 116 HP), complete chassis and body repair.
Power:
143HP 212Nm
0-100km/h about 8-8,5s
vmax 207km/h
Drive:
-EJ20 SOHC engine
- throttle from EJ25
- intake manifold from EJ22 plus porting
- GT injectors
-custom exhaust manifold and muffler for honda 2.2 diesel
-Trabant fuel tank at the front
- 8bar replica Walbro fuel pump
Suspension and Brakes:
- Rapid gearbox and suspension
-polyurethane gearbox cushion
-polyurethane rubbers of the rear wishbones
- polyurethane rubbers of the front stabilizer
- front brake caliper Ford Scorpio Cosworth 2.9
-BMW e30 320 brake discs
-Mitsubishi front shock absorbers
- front springs from w210(rear)
- Rear springs from Navara D40(front)
- 4x100 cnc front wheel hub
- 35mm cnc adapter with 4x100 rear
-Rims 15x7 FONDMETAL 4000 HB
Other:
-battery moved to the front
- RECARO scorpio cosworth armchairs
- electric glass front
-central lock
- oil pressure and temperature indicators
-dashboard rapid / GLS
-black carpets
Power:
143HP 212Nm
vmax 207km/h
Drive:
-EJ20 SOHC engine
- GT injectors
Other:
-central lock
-black carpets
PanKu / skoda 120@EJ20 subaru - komentáře:
22:49:33
30.05.2021
30.05.2021
PanKu
23:01:37
25.08.2020
25.08.2020
PanKu
Springs from Nissan Navara D40, fit on the rear of the Skoda. Wire diameter 16mm.
Updated description
Updated description
22:45:12
10.05.2020
10.05.2020
-> PanKu: Steel spacers? Crazy.
Btw: what parameters do Mercedes spring have? Do know them or did they just fit?
22:03:43
10.05.2020
10.05.2020
PanKu
adapter 35mm. 4x100.
steel 42CrMo4t.
maybe good?
steel 42CrMo4t.
maybe good?
12:50:34
05.04.2020
05.04.2020
Tom Troll
-> Luky: Řekl bych, že to dělaj nestejnoměrně dlouhý větve parohů, škodovka to jako jedna z mála čtyřválců vytváří siamskejma kanálama u pětikanálů (Ikdyž tam furt je, tak osmikanály mají i s litinovejma svodama a klasickou dvojtrubkou tlumičem mnohem míň znát typickej škodováckej "brum"). Boxery tohleto od přírody dělaj, protože maj proti sobě posunutý páry válců.
Unequal lenght headers.
11:26:16
05.04.2020
05.04.2020
-> PanKu: stejně zajímavý, že s jiným motorem to stejně má typický škodovkový zvuk
It is funny that even with different engine, it still has typical Skoda sound
01:07:14
05.04.2020
05.04.2020
PanKu
20:30:10
19.12.2019
19.12.2019
PanKu
Wow, thank you;)
02:29:01
19.12.2019
19.12.2019
-> PanKu: I "faked" a payment for you so you should be able to upload more photos.
11:54:48
31.08.2019
31.08.2019
PanKu
11:53:51
31.08.2019
31.08.2019
PanKu
Budiki :D
22:37:02
16.08.2019
16.08.2019
PanKu
You're talking about the rear wheels bouncing at startup. Maybe the rear springs, I have fitted with a Mercedes W124 E230, and polyurethane pads.
Thanks, but really 35% throttle opening was: D
116KM and 170Nm, but these engines have a nice graph, Nm high from the very bottom of revs
this engine is just perfect to 1xx
