Skoda 120 1987
previously it was 1.3 MPi, now subaru impreza engine (EJ20 N/A, standard 116 HP), complete chassis and body repair.
Power:
143HP 212Nm
0-100km/h about 8-8,5s
vmax 207km/h
Drive:
-EJ20 SOHC engine
- throttle from EJ25
- intake manifold from EJ22 plus porting
- GT injectors
-custom exhaust manifold and muffler for honda 2.2 diesel
-Trabant fuel tank at the front
- 8bar replica Walbro fuel pump
Suspension and Brakes:
- Rapid gearbox and suspension
-polyurethane gearbox cushion
-polyurethane rubbers of the rear wishbones
- polyurethane rubbers of the front stabilizer
- front brake caliper Ford Scorpio Cosworth 2.9
-BMW e30 320 brake discs
-Mitsubishi front shock absorbers
- front springs from w210(rear)
- Rear springs from Navara D40(front)
- 4x100 cnc front wheel hub
- 35mm cnc adapter with 4x100 rear
-Rims 15x7 FONDMETAL 4000 HB
Other:
-battery moved to the front
- RECARO scorpio cosworth armchairs
- electric glass front
-central lock
- oil pressure and temperature indicators
-dashboard rapid / GLS
-black carpets
Skoda 120@EJ20 first start
PanKu / skoda 120@EJ20 subaru - komentáře:
I'm curious how you get the starter there.
Skoda120@EJ20 powerslide drift
Skoda 120 swap EJ20 subaru
as for the paint on the car. There is a change in plans;)
wow, article about me ... shock
-> havlik:
-> castrol: největší problém tohohle auta je ta povrchová uprava karoserie:)
Skoda 120@EJ20 DRIFT onboard
Skoda 120@EJ20 układ chłodzenia
Engine cooling system tuning
daily and skoda
Skoda 120@EJ20 acceleration
Springs from Nissan Navara D40, fit on the rear of the Skoda. Wire diameter 16mm.
Updated description
-> PanKu: Steel spacers? Crazy.
Btw: what parameters do Mercedes spring have? Do know them or did they just fit?
adapter 35mm. 4x100.
steel 42CrMo4t.
maybe good?
Now the gas throttle opens almost to max, about 90%.
The sound is skoda it's true
this engine is just perfect to 1xx
It is great, low RPM, there is no sound at all, and I will add gas afterwards, and it is wrruuummmm
upraveno 2x, naposled 12.04.2020 00:56:28
