Skoda S100-1975 , I am the second owner!
Engine-781.135M -AMG with ECU Felicia 50kw only for spark, and Skoda Favorit intake manifold with carburetor adapter from SP-EL.cz and Skoda 135 carburetor, runs very,very,very well :)
Increased compression ratio, two springs on the valve, cylinder head porting
Felicia starter with reducer
Gearbox 5 speed- 3.90 with back system from Rapid 130.
Brakes: Front all system from Rapid 130 with 4 pistons, Back Caliper VW with pads, disc VW polo
All of the wheel hubs modified to 4X100 PCD
Springs: back Koni spring yellow from 130LR - front original 130L(soft springs)
Shocks: back Bilstein gas Ford Escort Cosworth(Minor modification) - front Mitsubishi Pajero 3.0 V6 with hardness adjustment
Exhaust: Citroen C1 modified (So it sounds like stock)
Wheels: KN Diamond 14x6J PCD 4x100 Made in England very light wheels (Same manufacturer as original Skoda alloy wheels)
Tires: front and back - 165/70/14
I don't understand Czech. Please write in English.
000Nyk/Skoda S135 MPI - komentáře:
22:21:26
03.09.2023
03.09.2023
nyk23
Can someone help me with a camshaft for Felicia 50Kw? 136M: [DP]: 254/254 (22+52/57+17). A company that sells something like this or if there is someone who has one for sale, Thanks in advance!
22:38:32
07.02.2017
07.02.2017
nyk23
Crankshaft is standard 60mm, connecting rod the same standard 45mm.A good thing!
22:55:20
06.02.2017
06.02.2017
nyk23
I will make very exact measurement...ATS are available for sale, the car now has the original suspension and wheels 13, 5 speed gearbox sk rapid(this is how i bought the car).No stikers.And now the Favorit engine.I need only exhaust manifold sk 135.
22:20:30
06.02.2017
06.02.2017
11mAjA11
As You are 100% sure that engine is in original state, it can be original grinding, it mean that crankshaft diameter will be 60mm.
But this is so old engines and can by after some repair, measurement need to be done for 100% sure.
PS: that ATS are so cool I had similar at my first Golf MkII
21:36:56
06.02.2017
06.02.2017
nyk23
I know, but do not need to rectify crankshaft, only main bearings must change, have a little wear.Tomorrow I'll put the micrometer on the crackshaft... Thanks man!
21:21:29
06.02.2017
06.02.2017
11mAjA11
You can check ETKa www.oemepc.com/skoda/.../
e
There is diameters according to grinding, it mean that when You measure diameter of crankshaft You can easily found which bearings You need.
20:47:30
06.02.2017
06.02.2017
nyk23
Can someone help me with a code for crankshaft bearings 12416546 - 291ZVL , engine Favorit 781.135. That I found in motor. I want to know if this is standard crankshaft bearings. I know the standard code is 047105561-047105591 Favorit-Felicia. Thanks!
19:26:14
20.01.2017
20.01.2017
nyk23
Who knows Czech is easy,It would be about 50 euros, but who knows if sent in Romania
13:10:06
20.01.2017
20.01.2017
11mAjA11
Price is not so low but I think it is original..
auto.bazos.cz/inzerat/... /Vnejsi-zpetna-zrcatka-BES KYD-SPORT.php
11:24:43
08.01.2017
08.01.2017
nyk23
Thank you! I will look for another model...:(
11:21:17
08.01.2017
08.01.2017
-> nyk23: Today? Nowhere. Stock is sold and new production will be hardly made. It was available 1 year ago but it is not today. You can only check used parts.
11:18:08
08.01.2017
08.01.2017
nyk23
Where to buy a set of mirrors model Beskydsport?
17:33:53
21.10.2016
21.10.2016
FrantaM
God damm!!! Beautiful car. But these cars are like youngtimer, and are more beutiful in original. So, this is your Skoda, you can make, what you can...
21:24:31
12.02.2016
12.02.2016
nyk23
That's right
19:20:20
11.02.2016
11.02.2016
11mAjA11
No problemo.
Skoda family must help to everyone.
07:44:33
11.02.2016
11.02.2016
nyk23
Thanks man!
06:08:50
11.02.2016
11.02.2016
11mAjA11
According to my information You can swap that ECUs without any other HW changes.
It has only software differences.
Just re-code immo and it must working well.
20:34:43
09.02.2016
09.02.2016
11mAjA11
If it is possible send me complete number from that ECUs I can ask one of my frine who works in Česana (Škoda Auto - electric department) maybe he can help in this case.
Or take a picture of stickers from both of them, it will be sufficient.
20:12:31
07.02.2016
07.02.2016
nyk23
Do you know the difference between ECU 40kw and ECU 50kw from Skoda Felicia? Is a difference between them? Or difference is the engine only. Thanks in advance!
