Skoda135 GLi 04/1988-08/1989
Compression: 8,8:1
Power at 5000rpm is 41KW
Torque at 3500rpm is 92Nm
Transmission: 4,22:1
Max.speed:140km/h(Skoda Rapid135i:148km/h)
Inlet valves: 0,25mm
Exhaust valves:0,20mm
Fuel pressure:0,75Bar
Ignition spark advance:14 +/- 5 crankshaft degress
Alternator pulley:Skoda 135i Bendix
Distributor:443 213 204 720 Skoda135i Bendix and Favorit135Le,Lse
Plug leads:Ripaults SU267P
Flywheel:Skoda135i Bendix
Inlet manifold:Skoda135i Bendix
Exhaust manifold:Skoda135i Bendix and Skoda135,136,Rapid135,136
Air cleaner body:Skoda135i Bendix
Mechanical fuel pump:Jikov OD3457 Favorit1987-1992
Emission very good:CO 0,1-0,2%, HC 50-60, Lambda:1,00-1,01
(New Oxygen Lambda Sensor+Catalytic converter+Modifications E.C.U.)78000km
Injector:Renault 5,9,11,19,21 1.4i,1.7i(8983500063)
Throttle Position Sensor(TPS):Jeep Wrangler 2.4i,Cherokee 2.4i(1987-1990),Renault 5,9,11,19,21 1.4i,1.7i Automatic transmission(8933000169,3 3000169)
Idle speed actuator:Jeep Wrangler 2.4i,Cherokee 2.4i(1987-1990),Renault 5,9,11,19,21 1.4i,1.7i(8983502375,8350 2375)
K3727010(90365)White 12/1988
K3745835(90611)Apollo Red 02/1989
K3748523(90674)Brown 03/1989
The first model chosen to comply with the US-83 Federal is Skoda 135i.To accelerate the development,cooperation has been establised with the American company Bendix Electronics which manufactures an electronically controlled,single-point fuel injection system for Renault R9(Alliance) and Jeep 2.4 l cars destined for the US market.Components of the system have been employed on the Skoda 135i car,with just a few minor modifications,the most important one concerned with the electronic control unit optimizing the car engine operation.A single-point,electronical ly controlled fuel injection/ignition system manufactured by Bendix is employed to blend the fuel mixture in an optimized manner to ignite it ,which features a feedback from a lambda probe fitted into the exhaust pipe.The additional combustion of exhaust fumes takes place in a catalytic converter situated upstream of the exhaust silencer.The system guarantees that the provisions of the most stringent US-83 Federal regulation are met for at least 80.000 kilometres.
Imported parts:
2. Injector body 004-301374
7.Coolant temperature sensor 004-435006(Renault 7700737571)
8.Air temperature sensor 004-435007(Renault 7700737572)
15.Fuel filter 004-312109(Fram G3641 8933000076,33000076 Renault,Jeep)
16.Fuel pump 004-319153(Walbro NO.5611)
17.Activated carbon tank 007-622031(AMC 8933000056,33000056 Renault,Jeep)
19.Hose 005-311291
20.Hose 005-311286
21.Clip 007-606195 2pcs
22.Clip 007-606194 2pcs
34.Catalyst c/w accessories 003-245009(Walker UOP 4C PMR-102)
35.Packing ring 005-416095 (Walker AMC 8933000112, 51x66x14)
36.Stud 005-221556(Walker AMC 8934202175)2pcs
37.Nut M12 005-285334(Walker AMC 11502723)2pcs
38.Conical spring 005-056159(Walker AMC 8933000534)2pcs
46.Oxygen probe 004-165006(Autolite 3235910) 3 wire special titanium, only Skoda135i !!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!
47.Revolution scanning unit 004-165005(S100540015)
48.Electromagnetic valve 004-387121(Rostra T820100)
50.Sparking plug 004-081152(Bosch F7DC)4pcs
57.Indented belt 943-097509(Continental Foza V 10/9,5x1000La)
58.Battery 004-016139(Pakassaku Fi. Super Power 827)
60.Underpressure sensor 004-165007(ACDELCO 16018622) "876"
61.Control unit 004-046001(S100817101A) only Skoda135i !!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!! !
62.Ignition unit 004-050004(S100620-005A)
63.Series resistor 004-073121(AMC 8933000764)
66.Wiring harness 007-902444(Labinal Fr.)
68.Hose 005-311295
69.Hose 005-312487
70.Hose 005-320200
72.Fuel tank 007-650508(Kautex)
74.Hose 005-320202
81.Hose 005-311288(CPIO)
82.Hose 005-311290(CPIO)
83.Hose 005-311287(CPIO)
84.Hose 005-311289(CPIO)
91.Relay 004-025114(ELMOT 541 Poland 30A)2pcs
Compression: 8,8:1
Imported parts:
19.Hose 005-311291
20.Hose 005-311286
68.Hose 005-311295
69.Hose 005-312487
70.Hose 005-320200
74.Hose 005-320202
Robi135GLi-HU - komentáře:
Fuel consumption:5,8-7,6 liter 95 Bleifrei
I have 2pcs. used 135i-5speed emblem(RiC)
White GLi:
900rpm CO:0,62 Lambda 1,03
2800rpm CO:0,65 Lambda 1,01
White GLi:
-> Pitrys:
Emission???How big???
CO???
0,5?
CO???
0,5?
-> Pitrys:
Exchange rear Catalyst emblem
Robi---yes i have,look at rear car karlos.it is interesting,two emblem RiC!!!
Pitrys!!!
Have you got rear Catalyst emblem???
Tuxik---ty říkáš rapid injection catalyst,já si to taky myslím,ale Robi píše rapid injection coupe,musí být přece jednotný název,né?
there is no more info
K3705694-90095(Canada) Manufactured date:1988.10.
K3781675-91095(Finland)Ma nufactured date:1989.07.
-> Tuxik:
K3705694-90095
K3727010-90365
K3727808-90375
K3745835-90611
K3748523-90674
K3752653-90703
K3754090-90717
K3759767-90784
K3781675-91095
K3705694-90095
K3727010-90365
K3727808-90375
K3745835-90611
K3748523-90674
K3752653-90703
K3754090-90717
K3759767-90784
K3781675-91095
-> Pitrys:
RiC-Rapid injection Coupe
Rakousky -Ri Coupe
Rakousky -Ri Coupe
-> Tuxik: karoserie je totez co body
-> Robi135GLi-HU: where I can found serial number of car ? i have got car with changed body (i dont know how to translate word "karoserie") - 135GLi with incomplete engine, but I havent got number on front part of car (picture 15,16)
sorry for my bad english :-)
is it possible to find number of car from VIN ?
-> Pitrys: ric == rapid injection catalyst
Robi---17foto is super
Robi---RiC:(rapid injection coupe)or(rapid injection catalyst)?
-> Pitrys: The numbers Estelle 135GLi,136GL
Estelle135GLi:Boris!!!,Ka rlos135?,Paris,...
Rapid135i:Dale,Mailo,Karl os,Peta:),Wambobby
-> Pitrys:
Rapid injection Coupe(RiC)Export Austria and England
~500-600pcs
~500-600pcs
Robi---do you how many pcs Rapid135RiC?
Robi---this numbers are Skoda?not Rapid
